R Installation
If you are planning to do the R assignments on your own computer (recommended), then here is a quick outline for obtaining the software.
  • There are two separate software programs. Most people find it easier to use RStudio. than just R, but you need to install R first before installing RStudio (analogously speaking: you need an cell phone before you can use an cell phone case).
  • If you have R and RStudio from a previous course, you still need to update to the current versions! (version 3.6.2 of R and version 1.2.5033 of RStudio)
Downloading R
Go to The Comprehensive R Archive Network (CRAN)
Windows:
  • click “Download R for Windows”
  • click “install R for the first time”
  • click “Download R 3.6.2 for Windows”
  • click “Save File”
Mac:
  • click “Download R for (Mac) OS X”
  • click “R-3.6.2.pkg”
  • click “Ok”
Installing R
  • Windows: double-check icon for R-3.6.2-win.exe
  • Mac: double-click icon for R-3.6.2.pkg
For the rest of these steps, it is okay to accept the default selections (but I will outline them here for posterity):
  • give computer permission to install
  • select language
  • agree to GNU General Public License
  • select destination location
  • select components
  • Startup options: select “No (accept defaults)”
  • select Start Menu Folder
  • select Additional Tasks
  • (wait a minute or two for installation to take place)
  • “Click Finish to exit Setup”
Downloading RStudio
Go to the RStudio Desktop download page (i.e. we are using the free, desktop version of RStudio)
  • Windows: click RStudio-1.2.5033.exe, click “Save File”
  • Mac: click RStudio-1.2.5033.dmg, click “Ok”
Installing RStudio
  • Windows: double-check icon for RStudio-1.2.5033.exe
  • Mac: double-click icon for RStudio-1.2.5033.dmg
  • “Click Next to continue”
  • Choose Install Location
  • Choose Start Menu Folder
  • “Click Finish to close Setup”
Code Packages
For R coding, we will often need more code—called code packages. To ease our coding sessions, please run the following lines of code before class (in the lower-left console area of RStudio, just has to be done once this semester).
package_list <- c("tidyverse", "readxl", "mosaic", "titanic")
install.packages(package_list)
File Types
Also, while we are learning how I want homework assignments to be submitted, it will be useful if you can see file types in your computer.
Related
